FACE MACROS FOR PRESSURE
Old   April 10, 2008, 10:33
Default FACE MACROS FOR PRESSURE
Sandilya Garimella
Hello All
I am trying to solve for a compressible flow with pressure inlet BC
The user manual says that total pressure should be input in the inlet BC for pressure in the case of compressible flows
My inlet velocity varies with time and hence I plan to write a UDF to define total pressure BC at inlet.
For this I am doing the following
P_BC = P_static + 0.5 * density * velocity*velocity
T_BC = T_static + velocity * velocity / Cp
To access the pressure and temperature on face of boundary the manual gives the macro
F_P(f,t) and F_T(f,t) --- Is this pressure and temperature outputted by solver to UDF static pressure and temperature or total pressure and temperature? Because this affects the way i formulate my formula above
Please let me know
Thank you
Sandilya
Old   April 11, 2008, 09:04
Default Re: FACE MACROS FOR PRESSURE
bohis
I am pretty sure (same like you are pretty) that F_P(f,t) is macro accessing static pressure.
Ħque lo pases bien!
Old   April 11, 2008, 09:06
Sandilya Garimella
Thank you very much
Old   April 11, 2008, 09:13
bohis
de nada
Old   May 4, 2012, 06:12
Luca Gorasso
elcino is on a distinguished road
Send a message via Skype™ to elcino
Yep, F_P is for static pressure (relative to operating pressure)
elcino is offline   Reply With Quote
macros for pressure drop Dr C.Bhasker Siemens 5 April 9, 2012 12:24
Average pressure on a face. Mario Tremblay CFX 2 February 19, 2009 13:08
how to color the face by pressure or volecity? superfool FLUENT 0 January 2, 2007 19:51
Orientation of Face Variable Macros hirokata FLUENT 0 February 17, 2006 00:12
Macros for pressure values!! Thiyaga FLUENT 0 June 11, 2005 00:27
