fluent error
Old   July 6, 2004, 22:02
Default fluent error
ashish aleti
hi all,
i am getting this error message "pressure-outlet zone 5 has tow adjacent cell zones". can anyone help me with this problem.
I am trying to create a room with a window. lemme know if the following procedure is correct.
the 4 walls of the room are defined "wall" the opening in the wall is defined "pressure outlet" the outside envirnoment is defined as follows, the veocity inlet definition is for the wind. and the other two sides of the envirnoment are pressure outlet. is this correct
thanks
Ashish
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
error while running paraFoam! padmanathan OpenFOAM 9 October 13, 2009 05:17
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
