December 4, 2019, 04:32 |
RSM turbulence low speed simulation
FHydro
Rep Power: 13 |
Hello. I hope you are all great.
I am simulating a channel in Fluent. When It simulates with k-epsilon, k-omega and other turbulence models, the cpu usage in 100% from starting of simulation to the end. But in RSM turbulence model, the cpu usage perodically goes up and comes back down and again.... Therefore, it results in very low simulation speed for this model compared to other ones. I know that RSM calculates 5 further equations but what is the reason of that cpu processing behaviour? Is it normal for this model? Thanks Last edited by flow_CH; December 4, 2019 at 08:55. |
December 4, 2019, 11:15 |
Lucky
Rep Power: 65 |
Are you running a large model cell countwise? Check if your RAM is bottlenecked. More equations means more variables have to be stored in RAM. If you RAM capacity is exceeded, you are dead. If your RAM speed is slow, the cpu can just be waiting on RAM.
December 4, 2019, 11:23 |
#3 | |
FHydro
Rep Power: 13 |
How can I check whether RAM's capacity is enough or not? I should check it during simulation? |
December 4, 2019, 11:58 |
Lucky
Rep Power: 65 |
Yes during the simulation. Check how many GB of your RAM is being used, and how many you have. If you are in windows, open the task manager. If RAM usage exceeds 80%, that could already be the problem.
Low Re Turbulence model VS Low Re flow and Turbulence Modelling background | pchoopanya | Main CFD Forum | 4 | May 10, 2018 11:05 |
RSM low Re Stress - Omega convergence issues | Jonathan | FLUENT | 1 | April 20, 2016 05:33 |
Bubble Column Simulation: Different Turbulence Models different results | zobekenobe | CFX | 5 | January 28, 2013 09:02 |
Low Turbulence Intensity Simulation | J. McCarthur | Main CFD Forum | 1 | October 26, 1999 16:17 |
Turbulence Intensity Vs CFD Simulation | Apple L S Chan | Main CFD Forum | 3 | December 15, 1998 17:28 |
