non-positive volume
Old   August 2, 2004, 04:56
Default non-positive volume
Wenbin Song
Hi there,
I am using fluent to model a 2D airfoil flow, the mesh was generated using Gambit with a boundary layer.
I am getting a warning message when using grid check in fluent:
WARNING: non-positive volumes exist.
minimum volume(m3): -3.565426e-12 maximum volume(m3): 1.663969e-01 total volume (m3): 3.139505+02
Face area statistics: minimum face area (m2): 8.642673e-07 maximum face area (m2): 6.597350e-01
Why am I getting non-positive volume while the minimum face area is greater than zero?
Could anybody give me a clue?
Thanks Wenbin
Old   August 2, 2004, 18:13
Default Re: non-positive volume
Ryan Zarnitz
Sometimes this happens with gambit. The solution is to use the examine mesh tool in gambit to identify the problem areas and re-mesh them. The most common situation for me when this comes up is when there is a very narrow space between two volumes. Sometimes you can fix it using an alternate meshing algorithm, and sometimes you have to find a different way to subdivide the domain.
Old   August 9, 2004, 12:18
sijal
this is usually happen when two mesh lines are intersecting each other
check themesh quality and see the areas which are narrow and mesh quality is bad , u will oberseve the above said thing
regards
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
