August 12, 2004, 04:17 |
Getting data of injected particles
Hi everyone,
Does anybody know which is the best UDF to use, for getting the data (e.g. position, velocity, temperature) of injected particles in the flow, in each and every time step. I tried DPM_SCALAR_UPDATE, and also DEFINE_RW, but both were problematic. I need this data in a .dat file, which i can later read using Matlab, for further analysis. Thanks, Lior. |
August 12, 2004, 13:44 |
Re: Getting data of injected particles
you don't need UDF at all for particle history data. Just turn on STEP BY STEP option in display trajectory, you can either display particle history on screen or write to a file.
August 15, 2004, 11:14 |
I know that........ But there's a problem with it - The files generated from the 'Step-By-Step' option, are given with NO Particle ID, which means that if i look at different particle file for each time steps, i can't recognize what happened to a single particle, cause there are no IDs in these files......
DO you have an advice how i can get over this problem? Of course i'd rather to do it without using UDFs.... but without particle IDs , it's useles... Thanks again, Lior. |
August 16, 2004, 11:23 |
I don't know how many particles you are tracking. If less than 10, then you can look at the history file. Each particle start with first column (time) = 0, which serves as kind of particle ID.
August 16, 2004, 16:14 |
Hi wxl,
Thanks for you response, again. I am injecting one particle each time step, in an un-steady flow with an inlet-flow boundary condition... I have ~80 time steps in each cycle, which makes it 80 particles to be injected and tracked until they leave the vessel... Hence, particle ID is very important... What choice do i have then, of the particle number is higher than 10? Thanks, Lior. |
August 18, 2004, 15:53 |
Hi Lior,
It really is the easiest way to track particles by writing out the step by step files into a *.part file I am currently using the data of several hundred to thousand particles injected into a steady solution though (hope this works for unsteady too). The part files are just divided into columns and the first column is the time of the particle in the reactor. In my case I wrote a small data loader that reads the values line by line and assigns a new particle ID each time the first column value is smaller than on the last line. This works in my case since the particle values just continue until it exits the reactor before the next particle is started. I would wagger a guess that it is the same for unsteady flows. You could also write an UDF to write the data of each particle in a separate file I guess. Feel free to contact me if you need some help |
August 19, 2004, 12:55 |
Hi Angello,
First of all, thanks for your help. Now, about the "step by step"... in my fluent version (6.1.22) i think you mean the "current positions" option, which exists in the "display/particle tracks" panel... I generated files using this option, but as i mentioned before, they miss a particle ID, or a way in which i can understand to which particle this data refers, in case there are many particles... About the "Write/Start Particle History" option - i used it, but got very weird files, in which i don't understand what the data means... I also think they do not include all the information i need (positions, velocities, temperature, time, and above all - particle identification.... In Fluent help they also don't explain about the format of the particle history file: "FLUENT will write the position, velocity, and other data for each particle at each iteration or time step."... This is not enough to understand this .phs format... Anyway, if you have any advice i would be very thankful.... Thanks again, Lior. |
August 19, 2004, 14:25 |
Hi Lior,
Lets go step by step and eliminate the errors. My setup: Fluent 6.1.22 Solver: Implicit, steady, 3D single precison Fluid: Water, Turbulent, ke-Realizable Domain: 3D, Cooper, 0.2-1.5 Million Cells (in different models) Converged Solution. Open Discrete Phase Panel. Set Injection to surface, inlet, innert, antracite (set to same density as water!). maximum steps 15000 (depends on your model) Step lenght 1-5 (model dep.) Open Particle Tracking Panel report step-by-step, report to file, pulse mode single, WRITE --> gives "filename.part" file Open filname.part in Text editor you will see something like: FILE TYPE: 1 COLUMNS: 11 TITLE: TRACK HISTORY COLUMN TYPE VARIABLE (UNITS) ------ ---- -------- ------ 1 2 TIME (SECONDS) 2 10 X-POSITION (METERS) 3 10 Y-POSITION (METERS) 4 10 Z-POSITION (METERS) 5 10 U-VELOCITY (M/SEC) 6 10 V-VELOCITY (M/SEC) 7 10 W-VELOCITY (M/SEC) 8 10 DIAMETER (METERS) 9 10 TEMPERATURE (KELVIN) 10 10 DENSITY (KG/M3) 11 10 MASS (KG) --------------------------------------------- 0.00000e+00 -1.43826e-17 -2.34893e-01 -1.43167e-02 0.00000e+00 0.00000e+00 0.00000e+00 1.00000e-06 3.00000e+02 1.55000e+03 8.11578e-16 etc. The first column contains the timesteps for each particle, particles are saved below each other i.e. Particle 1: all time steps until it leaves RK followed by Particle 2 etc. There are NO gaps between particles, the only way you know a new particle starts is looking a the time column and watch for a new near 0 value Solution: read filename.part line by line (easy to programm in c++ but should also work in Excel VB) and each time the new value in the first column is SMALLER than the last value a new particle has started. Increase Particle ID and continue. I don't know how this looks in unsteady solutions but should be simillar Hope I could be of assistance Angelo Sozzi |
August 19, 2004, 16:11 |
OK thanks.... But I don't think this works for unsteady cases... Anyway, i will write you an email, and discuss it more thoroughly there...
April 9, 2020, 13:31 |
#10 | |
mohamad ali mirzaei
Rep Power: 9 |
April 9, 2020, 14:12 |
Response
#11 |
You may but I doubt that you will get a response since the post is quite old. I would recommend posting your own query.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
how to determine the number of particles injected. | welch | FLUENT | 2 | January 18, 2024 05:08 |
trying to simulate two-phase jet flow with particles in surface injection | ajkratos | FLUENT | 5 | March 3, 2015 22:33 |
how can I increase the number of injected particles? | sfotovati | FLUENT | 1 | July 14, 2010 04:54 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 18:27 |
Defining New Material for Injected Particles | Lior | FLUENT | 5 | June 4, 2004 12:12 |
