August 14, 2004, 03:50 |
Parralel processing
Hi
1.I need to know that wat type fo hardware is required for parralel processing for fluent on windows xp 2. Is the conventional LAN is enough for parralel processing. Is not that wat is the solution Any help will be greatly appreciated. Thanks in advance Regards Sijal Ahmed Memon |
August 14, 2004, 10:23 |
Re: Parralel processing
hi, SAM
I think no special types of hardware are needed. conventional LAN is engough if the communicaion between nodes is not very large. good luck |
August 14, 2004, 14:51 |
If the problem is highly 3D with unsteady option on , then conventional LAN is ok
August 17, 2004, 09:32 |
It will work, but if you have it split too many times then the LAN communication wastes more time then you gain by using multiple processors. I routinely run 3D, turbulent, and compressible jobs across a LAN, and have run several 3D, unsteady jobs as well. It seems to be a trial-and-error process to figure out the optimal number of parallel processes.
I have noticed that once a converged solution is found (by monitoring residuals, force coefficients, and usually the pressure at a couple points) there is a small mass imbalance near where the partitions intersect the flow boundary conditions (like pressure-far-field or pressure-outlet, but not wall or symmetry), but it is small and does not seem to effect the solution, as far as the forces or the pressures on the wall surfaces, but it does seem to drag the convergence out some if you watch the residuals. This may be another reason to try not to run it on too many processors. You can plot this mass imbalance under the plot-contours window. |
Parallel processing of OpenFOAM cases on multicore processor??? | g.akbari | OpenFOAM Running, Solving & CFD | 31 | November 1, 2017 09:25 |
NO model vs post processing in coal combustion,CFX | sakalido | CFX | 1 | April 15, 2011 14:07 |
post processing for KIVA | dirga | Main CFD Forum | 5 | April 23, 2009 10:58 |
bubbly flow and parallel processing | mvee | FLUENT | 0 | September 12, 2007 05:08 |
Post Processing in FEM | Abhijit Tilak | Main CFD Forum | 0 | April 26, 2004 11:59 |
