August 11, 2004, 06:04 |
Combustion expert?
I'm modelling a solid fuel (lignite) combustion in a 3d furnace (non premixed combustion). For the fuel, one empirical stream will be used in prePDF (CHONS concentrations are known). How can I include the fuel moisture? Do I consider of it when I define the injections (If yes, where?)? (Wetcombustion page is not available under my current settings, although H2O(L) is included in the species in prePDF).
I have read the "Non premixed combustion" and "Discrete Phase" user guides and the corresponding tutorials, and I understood everything else, except for this. Is there something that I miss? |
August 13, 2004, 02:12 |
Re: Combustion expert?
define it as water in vapor form or as u requires..specify model fraction in prdpdf and calculate the look up table
August 16, 2004, 03:55 |
Thank you for answering my question but how is it possible to include vapor (H2O) concentration when I want to use only one, empirical fuel stream (CHONS fraction definition)? Should I convert the water content to CHONS atom fraction and add the latent heat in material properties panel (for fuel)?
Modelling Combustion in Porous Zone | tanjinjack | FLUENT | 2 | September 26, 2016 04:10 |
hydrocarbon gases + Boron particle combustion | nileshjrane | OpenFOAM | 1 | December 13, 2010 06:20 |
Hydrogen Air combustion in a combustion chamber | popi | CFX | 7 | July 11, 2007 18:40 |
Need Similar Combustion Tutorial as my model | Arnab | Siemens | 0 | May 24, 2005 18:23 |
Multiresolution + Turbulence + Combustion | Raul | Phoenics | 1 | March 31, 2005 08:51 |
