August 19, 2004, 16:09 |
Airpak: natural convection in a duct
I made 3 models of a 200m long duct with two 1m^2 wide openings. They were angled at 30 degrees, 45 degrees, 60 degrees and 90 degrees. The first 3 respective ducts worked fine. They had one side with a 500W heat flux, and the other sides ambient... and the air flowed out of the top side at speeds increasing with angle as expected. However, the 90 degree (vertical) duct gave me some problems. The solver would not converge, and showed a circulation pattern inside the duct, with the downdraft side actually running along the heated side... clearly not realistic. Any suggestions on how to model convection off of a vertical heated side along the length of a duct? |
August 27, 2004, 05:53 |
Re: Airpak: natural convection in a duct
have u switched off the radiation solver option ?
August 27, 2004, 13:28 |
Actually I didn't. I'll give it a try, since 1 meter is definitely a small enough length to cause some heating on all sides.... however, it didn't happen in the other 3 angles.
natural convection problem with radiation | jorien | CFX | 0 | October 14, 2011 09:26 |
Natural Convection with heat generation | krishnachandranr | Main CFD Forum | 0 | July 28, 2009 04:22 |
Natural convection - Inlet boundary condition | max91 | CFX | 1 | July 29, 2008 20:28 |
Coupled vs Seg - Natural vs. Forced Convection | Alex | Siemens | 5 | December 12, 2007 04:58 |
natural convection in a vertical heated duct. | SHANTANU CHAKRABORTY | Phoenics | 1 | June 18, 2001 09:12 |
