boundary conditions
Old   September 20, 2004, 05:16
Default boundary conditions
Karthick
Hello all
I am using dynamic mesh model which simulates the movement of shuttle due to pressure difference across either sides. But the problem is I declared the piston face as wall, where I am specifying the velocity. Also I need two walls(piston entry and exit faces where the pressure has to be measured). This difference in pressure is converted to velocity of piston. So I have to declare two boundary conditions to a particular edge. But Gambit is not allowing me to do that. Either of one is possible in it. Is it possible by anyway to declare 2 BC to a particular entity?
Regards Karthick
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
OpenFOAM Variable Velocity Boundary Conditions NickolasPl OpenFOAM Programming & Development 2 May 19, 2011 05:37
[Netgen] boundary conditions and mesh exporting vaina74 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2010 09:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
