CONTOURS LINES
Old   August 30, 2004, 05:55
Default CONTOURS LINES
Tania
do you know how to add contours lines in fluent.
Thanking you in advance,
Tania
Old   August 30, 2004, 06:58
Default Re: CONTOURS LINES
Bob
You can adjust the number of levels.
Old   August 30, 2004, 07:51
Tania
Actually, I want to present my results (for examples the pressure) as contours lines and filled colors at the same time.So, I would like to have the different colors separated with a line.
I didn't manage to do it in fluent. Either the results are presented as contour lines or filled with colors, but not the two at the same time.
Old   August 30, 2004, 08:11
Bob
This cannot be done in Fluent, but I use Tecplot and you can have the contours multicolored and the lines any color you want.
Old   August 30, 2004, 09:00
Tania
Ok, thanks !
Best regards,
Tania
Old   August 30, 2004, 13:29
SAM
this can be done in fluent
First draw the countors with lines
then go to display > scene munu
click on overlays and click on apply
now go to countrous and tick on filled and display cournts
u will have both things at time
but i suggest u to use tecplot. as it gives u more option to manipulate ur data
Ragrads
Old   August 30, 2004, 14:49
Tania
It works !!! thanks a lot !
[Tutorials] Tutorial of how to plot residuals ! wolle1982 OpenFOAM Community Contributions 171 February 20, 2024 02:55
Plotting Residuals ata OpenFOAM 12 July 8, 2011 02:50
coloured grid lines instead of contours Matthias FLUENT 8 December 10, 2008 19:09
Preconditioning and pressure contours ganesh Main CFD Forum 2 February 18, 2006 00:02
extension for liquid fraction contours venugopal FLUENT 0 June 11, 2004 01:27
