September 10, 2004, 06:49 |
temperature
what is the difference between total temperature and static temperature for compressible flow?
thanks in advance. |
September 22, 2004, 03:08 |
Re: temperature
The total temperature is the the temperature of the fluid if you think to arrest it isentropically (from its conditions). The compressibility of the fluid "is visible" observing a non-dimensional number: the Mach number, defined as the ratio between velocity and the speed of sound (at the considered temperature). The link is given through the equation:
Tt/T=(1+((gamma-1)/2)*(Mach)^2) Gamma is the ratio between the specific heat at constant pressure and at constant volume. FSL |
Problem with zeroGradient wall BC for temperature - Total temperature loss | cboss | OpenFOAM | 12 | October 1, 2018 06:36 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Bulk temperature Tf is obtained from total or static temperature? | NPU_conanxie | FLUENT | 0 | March 30, 2011 05:56 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 17:31 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
