external variable for pressure-gradient
Old   September 7, 2004, 19:35
Default external variable for pressure-gradient
Indy
hello,
I am using periodic flow. It would be nice if I can use "pressure-gradient" or "mass-flow-rate" information inside of my UDF code.
I've checked the header file of sg_press.h
there is interesting definition that i want to look at but how can I access that variable?
If I try to call it out it shows error message.
it's alread defined ....
Thank you, all of you (especially Greg) I've learn lots from you.
K.H.
Old   September 9, 2004, 01:15
Default Re: external variable for pressure-gradient
indy
oh well,
I guess I just have to code a bit more to compute those variables from fluid field
indy.
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 01:40
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
Gradient of a User defined Variable Ramadas CFX 2 August 21, 2007 09:19
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
