Heat transfer through solid.
Old   September 4, 2004, 06:43
Default Heat transfer through solid.
Rob Hart
I have a solid zone within my fluid, and I want to model the heat transfer from the fluid into the solid.
I have meshed the geometry in gambit, and when I load the mesh in fluent, the boundary between the solid region and the fluid region shows as "coupled" for the thermal conditions.
When I run the model, the solid region stays at it's initial temperature.
What have I missed?
Rob
Old   September 7, 2004, 00:30
Default Re: Heat transfer through solid.
Mahesh Masurkar
Everything is correct. Check for material properties. Wait for convergence. Mahesh
Old   September 7, 2004, 05:18
Andrew Garrard
Have you got a shadow face set the boundary condition correctly on the shadow face?
Old   September 8, 2004, 11:49
Krishna
Hello Rob,
A couple of things to note when you are modelling conduction through a solid:
(1) Use a higher-order scheme like "Quick" for your for solving the energy equation.
(2)Make sure that your solution has converged fully.
Krishna
Old   September 30, 2004, 07:58
venu gopal
Dont select coupled option in this case. Do one thing. Select the temperature after deselcting the coupled. If two different thermal conductivity substances are separated by a wall or edge ( eith both are solid or one solid and one fluid) it will take couple as a default. So, you select the temparature and speciy it and it will work nicely.
Venu Gopal
Old   October 17, 2004, 08:59
Default Re: Heat and temparature
koksal karadag
Biz Türkiyeden iki arkadaşız.ingilizce bilmediğimiz için türkçe yazdık bir konu hakında bilgilendieieseniz bizi çok memnun oluruz bizim konumuz ısı ve sıcaklıkla ilgili kavram yanılgıları.
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
No Heat Transfer between two solid domains Mike ZH CFX 7 July 26, 2008 16:50
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
