FLUENT Error
Old   October 11, 2004, 07:33
Default FLUENT Error
Ajay
I get the following error when I start FLUENT any remedies ?
Loading "c:\fluent.inc\fluent6.1.22\lib\fl_s117.dmp" Done. System clock has been set back Feature: fluent License path: c:\fluent.inc\license\license.dat FLEXlm error: -88,309 For further information, refer to the FLEXlm End User Manual, available at "www.globetrotter.com".
Hit return to exit.
Old   October 11, 2004, 10:56
Default Re: FLUENT Error
Tang
It looks like you have set your system clock back and whenever you open fluent it creates a log when it opens. Just, play with your windows clock until Fluent opens. Also, when does your license expire?
Old   October 12, 2004, 04:51
JJ
I have a similar problem. In my case, I get this message first Loading "c:\fluent.inc\fluent6.1.22\lib\fl_s117.dmp" Done
and then it says, error: sopenoutputfile failed. check output file. Anyone know what it is ?
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
error while running paraFoam! padmanathan OpenFOAM 9 October 13, 2009 05:17
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
