October 9, 2004, 04:58 |
how to caculate flame volume???
hello everybody:
i am caculating a combustion problem. and i can display the flame using oxygen mixture ratio from zero to 0.99. but i dont know how to caculate the flame volume??should i use any function or user defined fuction??? looking forward for your help> thanks!! |
October 11, 2004, 06:55 |
Re: how to caculate flame volume???
A little obscure way but it always helped me (save your case/data before you attempt it): [1] Goto Adapt->Iso-value. Put min-max values and get the cells marked out of it. (make sure you use "0.9999999" rather than just "0.99"), [2] Goto Grid->Separate Cells. Pick your register (of just marked cells) and the fluid zone(select all if you are confused). Click on Report to see what it is going to do. If you are happy with that, do "Separate". It should create a separate fluid zone, [3] Goto Report->Volume integrals and find the volume of just separated fluid zone.
Of course, you have to throw away your case file once you do this calculation. Not an easy way but it works fairly ok.. |
October 16, 2004, 03:02 |
thanks a lot! i tried once and it worked well.but i dont know why you put the max value to 0.9999999.
and after i seperate the grid i got two fluid zone, the flame value should be the samll value, but i dont known how to make sure, can you give me some advice??? |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
