October 18, 2004, 08:32 |
Need help about GAMBIT Neutral file
I'm programming to read 2D GAMBIT Neutral file for my own code. When proccessing boundaries, I find that in the node list of a boundary, the first two nodes are just the two end nodes of the boundary edge.
Does anyone know whether it is a rule of GAMBIT Neutral file format. If yes, it will make the code simpler. |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 04:59 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
set boundary condition in Neutral file, in Gambit | Vito Chow | FLUENT | 2 | April 26, 2005 06:50 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 22:00 |
