October 27, 2004, 12:22 |
error when mesh in Gambit
When I meshed a cylinder(h=665m, r=1000) using Tet/Hybrid in Gambit, mesh space is 1m, it always had a error: Tetrahedral meshing has failed ofr volume 1. This is usually caused by problems in the face meshes. Check the skewnesses of your face meshes and make sure the face mesh sizes are not too large in areas of small gaps.
But I think the mesh size already very small. Does anyone know what I can do for that? When I tried 20m for space it works, but this mesh is not fine enough. Thanks for advice. |
October 28, 2004, 02:58 |
Re: error when mesh in Gambit
Hey,
A thought on the matter: Have you let GAMBIT create the FACE MESHES automatically? I've had some success before with manually creating quad meshes all around the volume, which I have then split into triangular ones. Following this I've meshed the volume using either tet/hybrid- or TGrid elements. |
October 28, 2004, 14:11 |
Mesh the faces manually then use that scheme for volume mesh. (hope it solves the problem)
All the best Par |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
How to mesh a circle by Gambit? | Zhengcai Ye | FLUENT | 5 | March 24, 2006 01:04 |
[Commercial meshers] Mesh import from gambit | Kaushik Balakrishnan (Balakrishnan) | OpenFOAM Meshing & Mesh Conversion | 5 | April 21, 2005 13:42 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
