use sliding mesh to simulate unsteady flow
Old   November 8, 2004, 13:01
Default use sliding mesh to simulate unsteady flow
annie
hello, everyone. I use Fluent to simulate the unsteady flow. I have seperately produced the mesh for rotor and stator( I have assumed, dass they have the same blade numbers). And I merge the mesh for the rotor and stator.
But when i read the merged mesh in Fluent, and want to set the interface Boundary conditions. Error appear: Boundaries too far apart.
Who know, what is the problem? Thanks very much! Regards, Annie
Old   November 9, 2004, 04:05
Default Re: use sliding mesh to simulate unsteady flow
Domi
Perhaps there is a tiny gap between the two domains that you don't see in the graphics window but that nevertheless is there . Are you sure you merged the meshes correctly?
Old   November 9, 2004, 06:03
annie
hello,Domi. Must the interface (outlet of rotor and inlet of stator) completely be the same( X,Y,Z value)? You know, the mesh of rotor and stator is produced seperately(using Turbo). How can you control the geometry of interface?
Old   November 9, 2004, 07:48
Domi
Both domains have got to have an interface and both interfaces must be coinciding. They must have the same coordinates, I think. You generate the grids separately in Gambit or other software and then you put them in the right position using the tmerge command (cfr. fluent manual). That is the way I do it. I hope it works for you to.
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Polyhedra and sliding mesh? rockewan FLUENT 5 December 1, 2018 19:07
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Incompressible, Unsteady Cylinder Flow startingcfd Main CFD Forum 1 March 15, 2011 01:12
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
