Meshing Aircraft with Gambit
Old   October 29, 2004, 19:30
Default Meshing Aircraft with Gambit
Ed
I am attempting to mesh basic aircraft geometry using Gambit. I have had success by making a volume around the aircraft, subtracting the aircraft and then meshing all the surfaces with a fine mesh and finally volume meshing the created volume. I have used boundary layers on some models, but a lot of times, Gambit won't do boundary layers when I try to volume mesh. I use Tri elements on all the surface meshing. I use Tetmesh for the volume meshing. I am very frustrated with Gambit. It is never easy to create a quality mesh and even when I do make one that looks nice, I don't really know if it is high quality. I use size functions to create the surface meshes. Does anyone know if there is an easier way to create nice meshes in Gambit or if I should be using some other program to create meshes for use in Fluent? Thanks!
Old   October 30, 2004, 01:46
Default Re: Meshing Aircraft with Gambit
akula2
this is why there are meshers such as gridgen, icem etc. i am pleased with gridgen at all..
Old   October 31, 2004, 04:14
Jörn Beilke
http://www.gridpro.com/gridgallery/airplane.html
Old   October 31, 2004, 12:51
SAM
But it requres password.
do u have one?
if possible mail me?
regards
Old   October 31, 2004, 14:44
Jörn Beilke
I don't have the login data. Just send a email to support@gridpro.com and ask for it.
Old   November 9, 2004, 05:04
kyooko
Use tgrid. It is included in fluent package. For tetra-mesh it works well.
And you can get "DLR-F6" grid from http://aaac.larc.nasa.gov/tsab/cfdlarc/aiaa-dpw/
[ANSYS Meshing] ANSYS Meshing vs GAMBIT aerospain ANSYS Meshing & Geometry 0 September 28, 2011 06:05
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 01:09
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
