Floating point error
Old   October 29, 2004, 00:56
Default Floating point error
ssendai
hi, i installed Fluent6 in my PC. When i used the Display in Fluent solver to display the computed results, the following error msg are shown: Error: Floating point error: divided by zero Error object: ().
If you know the reasons, please e-mail me.
Thank you very much
yours
ssendai
Old   November 2, 2004, 11:01
Default Re: Floating point error
venugopal
One of the reason is because of improper boundary conditions and sometimes if you are starting the solution again it will not come.
Check your boundary conditions again.
Venu Gopal
Old   November 23, 2004, 08:02
Ruben
It is a problem of your graphic card. I had the same problem with my laptop. Ive got a ATI RADEON 9600 and I had to do the following:
If you are using Windows, try to decrease the hardware grafic acceleration of the sistem: Control Panel -> Display -> Settings -> Advanced -> Diagnostic -> Move the acceleration hardware cursor in the center of the graded scale.
NB: this is the english traduction of a Windows XP italian sistem, but it isn't too different from the other versions.
Bye
Rubén
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 06:11
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 21:23
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
