November 19, 2004, 19:59 |
static mixer volume meshing
i had drawn a single volume kenics static mixer in gambit .. i have already meshed all the face manually however, when i try meshing the volume, it just fail .. any suggestion on it ? thanks ..
regards .. |
November 24, 2004, 04:41 |
Re: static mixer volume meshing
hi can you give any error give during volume meshing thanks nabeel
November 24, 2004, 21:54 |
the error message says that it is unable to mesh due to some big gap in the small egde.... but i have already checked the meshing for every face and every face .. and i can't see any problems with it .. thanks
November 25, 2004, 01:07 |
hi have you make model in gambit or imported from cad nabeel
November 28, 2004, 08:17 |
yea i have made the model of the 6 elements static mixer in gambit... now is the process of meshing .. but i just couldn't mesh the mixer .. error message is "check the skewness of the face mesh , large meshing in small gaps " but i have try meshing the edge there after the face .. but still it doesn't work
error: uninitialized local variable 't' used | MASOUD | Fluent UDF and Scheme Programming | 5 | October 17, 2016 04:24 |
enum | MASOUD | Fluent UDF and Scheme Programming | 0 | June 5, 2010 00:49 |
Meshing volume | Eduardo | FLUENT | 0 | March 15, 2006 13:20 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
volume meshing | nikita | FLUENT | 1 | July 3, 2003 01:25 |
