Draw velocity profiles in tecplot
Old   November 30, 2004, 03:45
Default Draw velocity profiles in tecplot
scubme
Hi everyone:
My model is a pipe flow with one inlet and two outlets, which diameter is variable with the flow direction, and there is a symmertrical plane at Z=0 and XY-plane. The caculation had be finished in Fluent 6.1.
Now I want to use Tecplot software to draw some velocity profiles (X-axis is the diametry, Y-axis is the velocity magnitude) within the symmertrical plane along the flow direction.
I had tried many ways but no success. How can I do it? Please give me any suggestion, or if there is a tutorial ralated to the problem?
Old   December 3, 2004, 08:48
Default Re: Draw velocity profiles in tecplot
Hongfw
You try to interpolate the field value in the fluid zone to the symmertrical surface firstly, then plot the velocity magitude.
why can't I use tecplot to draw a streamline? hadesmajesty Tecplot 4 September 15, 2019 20:45
Free surface flow settubg boundary conditions and plotting velocity profiles prashanthreddyh FLUENT 2 October 21, 2015 09:58
How to draw velocity contours along the bend of U-pipe mariam.sara FLUENT 1 March 20, 2011 08:12
inlet velocity profiles? khelila FLUENT 0 February 6, 2006 10:28
Buy software for draw vector velocity Yassin FLUENT 0 January 18, 2006 11:35
