help wanted on interpreting a simple UDF
Old   December 5, 2004, 21:31
Default help wanted on interpreting a simple UDF
Suresh
Hi.. i have written a small udf to define the temperatute profile which is T = 200 sin(pi*t/10)...this is the temperature that has to be used as a BC on one of the walls of a 2d block. the accompanying udf is
#include "udf.h" DEFINE_PROFILE(unsteady_temp, thread, position) { face_t f;
begin_f_loop(f, thread)
real t = RP_Get_Real("flow-time");
F_PROFILE(f, thread, position) = 200*sin(0.314.*t);
} end_f_loop(f, thread) }
now wen i try to onterpret this UDF i get the following error mesage..cannot figure out whr the problem is...can anyone help...urgent...as i am stuck on the submission of an assigment on monday..ie dec 6th.. the error mesage is as below
C:\Fluent.Inc tbin tx86\cpp.exe -IC:\Fluent.Inc\fluent6.1.22/src -IC:\Fluent.Inc\fluent6.1.22/cortex/src -IC:\Fluent.Inc\fluent6.1.22/client/src -IC:\Fluent.Inc\fluent6.1.22/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" C:\wang\chetan-udf.c Error: C:\wang\chetan-udf.c: line 9: parse error.
....suresh
Old   December 6, 2004, 08:33
Default Re: help wanted on interpreting a simple UDF
hongfw
There is a erro in the line 9, please check "200*sin(0.314.*t)", the term 0.314. is not correct, it may be 0.314, or 314.0
Old   December 6, 2004, 15:33
Suresh
Thank you ...hong...actually it eluded me for quite a while but i found tht mistake ...thanx anyways... suresh
Old   December 8, 2004, 08:28
hongfw
I hope you can express what you want to say more clearly.
Old   December 8, 2004, 11:41
Suresh
well..hong i was saying thank you for the help extended.. by the way...u got any idea on modelling a screw compressor???
UDF programming fullmonty FLUENT 5 June 30, 2011 02:40
help for a simple UDF Greg FLUENT 2 April 14, 2008 10:53
I need UDF help. S.Whitney FLUENT 0 October 15, 2007 11:29
syntax error when interpreting UDF Erik FLUENT 3 September 27, 2006 07:52
wanted udf programm chandu&jignesh FLUENT 0 May 30, 2006 14:04
