December 7, 2004, 11:04 |
Gambit won't save?
Gambit runs no problem when whenever I go to save I get an out of disk space error, I have 100gb free though...
Any idea what is causing this? Is it a liscencing problem? |
December 7, 2004, 20:43 |
Re: Gambit won't save?
the reason for this is gambit starts in drive c: and when it tries to save there it gives this error, next time go to console and start that in some dir say c:\gambit, so after working try to save in that dir not in c: ...it shall work
December 8, 2004, 10:48 |
Not sure I follow, how can I start gambit in a directory?
I've just been running from F:\fluent.inc\ntbin\ntx86\gambit.exe |
December 8, 2004, 18:07 |
it doesn't matter you start gambit .. you should save the files in some folder like c:\gambit etc, if you are saving in c: then there is this problem .....
December 14, 2004, 19:32 |
That fixed it. Many thanks!
i cannot save file as ".dbs" in gambit. | ripong | ANSYS Meshing & Geometry | 2 | October 15, 2016 23:29 |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Does Gambit has a maximum allowable grid number? | spartan1516 | ANSYS Meshing & Geometry | 7 | March 25, 2010 09:08 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
