December 16, 2004, 03:50 |
How to define mass flow rate using UDF?
I have triied to define mass flow rate using UDF for unsteady calculation but unsuccessfully. The mass flow rate is a linear function of the time t (e.g. : q=a*t+b). Could someone tell me how to do this? Regards |
December 16, 2004, 06:17 |
Re: How to define mass flow rate using UDF?
I am afraid that we will probably need more information. Why is it unsuccessful? What error message, if any, are you getting. Also, can we see your UDF source code?
December 16, 2004, 09:30 |
Hi Andrew,
Thanks a lot for your answer. After many tries, we have found the solution by defining mass flux using UDF and not mass flow rate. Regards |
December 25, 2004, 01:36 |
Hello i am intersting in you UDF,can you tell me how you solve your problem or can you give me you UDF source.Thank you
Basic UDF for unsteady mass flow rate | emmkell | Fluent UDF and Scheme Programming | 2 | September 9, 2013 05:48 |
User defined function of mass flow rate | Eric | FLUENT | 1 | April 22, 2005 19:15 |
How to calculate the mass flow rate with UDF ? | HP | FLUENT | 0 | January 10, 2005 20:38 |
Target mass flow rate | Saturn | FLUENT | 0 | December 10, 2004 05:18 |
Mass flow rate | Neser | CFX | 4 | February 14, 2004 01:27 |
