How to modify iterated time in fluent UDF
Old   December 29, 2004, 22:49
Default How to modify iterated time in fluent UDF
scubme
Hi,everyone
My calculation is a coupled unsteady problem. After several periods, if the result is not meet the conditions of convergence,the calculation will be restarted from t=t0. Now , my question is ---
"How can I re-set the iterated time to the start time t0 in fluent UDF?"
Regards!
Old   December 30, 2004, 04:51
Default Re: How to modify iterated time in fluent UDF
Luca
Hi! you have to type in the TUI: (rpsetvar 'flow-time 0)
(NOTE: you have to type the parentheses too!) Now I try to do that using a UDF and let you know. Luca
Old   December 30, 2004, 05:47
scubme
Thank you Luca.
Is your method unique? Really, no other methods?
Old   December 30, 2004, 08:09
Luca
MMH.. I should think it over. Maybe we can find a method to use a UDF...we should look at the headers file and find something to initialize the flow-time. Luca
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 10:16
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 12:32
