ICEPAK Conitnuity runout under Solution Monitor
Old   January 26, 2005, 02:10
Default ICEPAK Conitnuity runout under Solution Monitor
Mario Cespedes
Hello guys,
I'm having problems in convergence with ICEPAK 4.1. The solver goes good until few iterations, then suddenly the continuity values goes up and up until numerical error 1e+12 from 1e-2. Energy and speeds look good.
Thanks in advance for your help
Mario
Old   December 12, 2011, 04:14
Pramodh.J
Jupudi.pramodh is on a distinguished road
Send a message via Skype™ to Jupudi.pramodh
There are several reasons for Divergence of a solution. One of the most common reason is the quality of the mesh.
Follow the instructions, this might help :
1. Let the solution diverge for 10-20 iterations.
2. Then terminate the solution and check the point of divergence ( the places from where the divergence has started) using the post processing object, ISO SURFACE.
3. Try checking the quality of mesh at those places and refine it.
In most of the cases, the reason for divergence may either be skewness or cell jump ( a very large dimension element placed adjacent to a small element) at the non confirmal surface.
In very rare cases , it can also be because of the case setup specified.
Hope this helps you.
Best regards
Pramodh
Jupudi.pramodh is offline   Reply With Quote
CFL Condition Matt Umbel Main CFD Forum 19 June 30, 2020 08:20
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 21:22
Doubt on Implicit Methods analyse In India Main CFD Forum 10 March 9, 2007 03:01
Discussion about Mesh independant solution Seb Main CFD Forum 13 May 22, 2001 13:37
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
