Convergence problem
Old   February 7, 2005, 04:05
Default Convergence problem
ocy
Hi all,
I am modeling a 2D chimney to study heat transfer in it.
At the base of the chimney, I have a energy source term for my fluid to simulate heat source.
At the top of the chimney, I specified pressure outlet as the boundary condition.
For the solver, I used coupled, implicit, steady, 2D.
However, even after 5000 iteration, my solution still do not converge.
Wonder if anyone out there who can help me solve this problem?
Thanks in advance.
Old   February 7, 2005, 04:55
Default Re: Convergence problem
Andrew Garrard
Sounds like a relativly simple problem?
Firstly, make sure your dimensions, like scale of grid (you wouldn't believe how many students get that bit wrong - often resulting in non-convergence), units of veloicty and heat source and temperature are correct and not orders of magnitude out.
Second, see if the problem occurs with Segregated solver
Third try lowering under-relaxation factors
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 06:00
convergence problem commonyue Main CFD Forum 1 December 1, 2009 03:54
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 22:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 00:24
