UDF question
Old   February 10, 2005, 08:02
Default UDF question
Pratap
Hi It is possible to access source terms of k and epsilon equation in UDF. Since I would like to make countour plots of them. Pratap
Old   February 10, 2005, 08:12
Default Re: UDF question
Andrew Garrard
C_K(c,t) and C_D(c,t). Although, you can of course make a contour plot from the standard GUI.
Old   February 10, 2005, 08:18
Default Sorry :-(
Andrew Garrard
Sorry, you said source term. I thought you mean't the actual value of k and e. If you make a UDF with a DEFINE_SOURCE term you can save the value you are returning to a C_UDMI and then use that to plot your contour. Make sure you turn UDM on in the fluent GUI.
Next time I should take the time to read the post.
Old   February 10, 2005, 08:35
Default Re: Sorry :-(
Pratap
I do not define any source DEFINE_SOURCE. I would like to access the souce terms of the kepsilon equation which fluent is solving. I have another question where can I have tutorial(pdf file) for PREMIXED Turbulent combustion using zimont model. Pratap
Old   February 10, 2005, 08:41
Andrew Garrard
If you are specifying a source term of K and epsilon in the Fluent GUI, it has to have a constant value or one from a DEFINE_SOURCE. If it is a constant value then you can simply slip that into your UDF using a #define (although the contours will look very plain) If your source term varies, then you can put it in as a DEFINE_SOURCE and use save the value to a UDMI and use that to plot the contours
Old   February 10, 2005, 08:53
Pratap
I think you are confuded with what I am asking. Let us say I want to "convective term of k-epsilon equation i.e term B in equation below " and plot its contours.Pratap
A+B=C+D A=unsteady B=convetcive C=Diffusive D=source term
Old   February 10, 2005, 09:45
Andrew Garrard
I understand now, it was when you said "possible to access source terms of k and epsilon", I thought you meant D as in your previous post. I am afraid that I don't know how to extract the value. I don't believe that you can get it in the UDF directly.
To create the value manually you need to extract the second derivative of k. I was trying to do a similar thing and posted a while ago, and never recieved a satisfactory answer. I would suggest e-mailing the fluent support to see what they have to say.
A simple UDF question Pirooz Darabi FLUENT 0 October 31, 2007 15:22
Basic question: UDF for wall heat flux Carl FLUENT 1 August 5, 2006 19:01
Question about UDF summer FLUENT 1 July 18, 2006 10:13
UDF question Ryan FLUENT 2 July 5, 2006 14:54
A question about the dynamic mesh UDF Tango FLUENT 1 November 27, 2003 02:56
