February 10, 2005, 13:19 |
convergence of energy
hi i am modelling a fuel cell ... 3 D geometry I have used a heat source term inside a porous volume. The trouble is that the solution is not converging for the order of the heat generation that i have given as input ( 9e9 W/m3)
After around 300 ierations, there is no significant change in energy residual, ( which starts at about 10e-4) and i get the results that i want, but if i continue the iterations till 5000 or more, the temp. keeps rising( and the solutions has stil not converged, residual keeps falling very slowly). I have tried changing UR factors, but it does not make any difference. I await your suggestions. Thank you |
February 12, 2005, 12:39 |
Re: convergence of energy
change the curent number and do a significant change of UR.
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
SIMPLE and energy equation convergence | Fabio | Main CFD Forum | 0 | June 1, 2007 06:06 |
Convergence problem for P1 & Energy | HP | FLUENT | 5 | May 21, 2005 15:01 |
Energy equation convergence problem | Reza | Main CFD Forum | 0 | August 27, 2003 13:09 |
