February 14, 2005, 01:33 |
Problem setting C_MU_T with DEFINE_ADJUST
Posted By: Andy Date: Mon, 9 Aug 2004, 7:34 a.m. Hi, i´m trying to change turbulent viscosity (for an extension of the ke-model; DEFINE_TURBULENT_VISCOSITY is not accessible in Eulerian multiphase) in the Eulerian model using UDF. I'm using a DEFINE_ADJUST , but I get an error message when I compile my code. The compiler tells me: error C2106: '=' :left operand must be l-value DEFINE_ADJUST(turb_adjust, d) { Thread *t; cell_t c; thread_loop_c (t,d) { if (FLUID_THREAD_P(t)) { begin_c_loop_all (c,t) { C_MU_T(c,t) = 1; /*C_MU_L works!*/ } end_c_loop_all (c,t) } } } Same error occurs for C_MU_EFF. But if i use the C_MU_L no problem (or C_R(c,t))! So where´s the problem with the eddy viscosity? I hope someone can help me out off this! Thanks. Andy |
February 24, 2005, 12:11 |
Re: Problem setting C_MU_T with DEFINE_ADJUST
no one replies,sigh~~~~~~
Problem setting C_MU_T with DEFINE_ADJUST | Andy | FLUENT | 3 | June 22, 2018 02:53 |
Problem in setting porosity region for rhoPorousSimpleFoam | run_cfd | OpenFOAM Pre-Processing | 1 | May 31, 2011 09:02 |
les setting problem, urgent | Frank | FLUENT | 0 | February 6, 2006 21:13 |
Problem setting AV | Marko | CFX | 0 | March 18, 2005 08:06 |
Help setting up combustor problem | Tom | FLUENT | 0 | February 5, 2005 01:20 |
