Accessing flow properties at certain points inUDFs
Old   February 14, 2005, 11:26
Default Accessing flow properties at certain points inUDFs
nicolas
Hi I need to obtain the velocity at a given point inside a udf. How can this be done? Thanks
Old   February 14, 2005, 14:32
Default Re: Accessing flow properties at certain points in
ap
You may loop over the cells, find their centroid with C_CENTROID and localize with an if clause the point you need.
Regards, ap
Old   February 14, 2005, 20:42
nicolas
But how can I know if a certain point is contained in a cell? The C_CENTROID macro gives the coordinates of the centroid of the cell, but the point I have may not be exactly this, but still contained inside the cell. Isn't there a macro to determine if a point is inside a cell?
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 05:18
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 07:33
