Grid Moving
Old   February 19, 2005, 06:51
Default Grid Moving
Karthik Krishna
Hai everybody, I am college student and doing a project in Grid motion. In a circular pipe (i.e. 2D), i want to rotate the inner side of the wall by 7degree in 1 sec. Outer Wall of the grid is fixed. My question:
1. It is possible in Fluent 6.0 using UDF by "DEFINE_GRID_MOTION" or "DEFINE_CG_MOTION" command.
2. I need to rotate the inner wall Grid (Nodes) for 7 degree.
If any body knows How to do this Plz. help me.
Thanks and regards, Karthik Krishna
Old   February 21, 2005, 03:23
Default Re: Grid Moving
HVN
Why don't you use mutiple reference frame method or sliding mesh method. It is explained in chapter 9 of the user's guide.
HV
Old   February 23, 2005, 06:29
Karthik Krishna
Dear sir,
I have tried in multiple reference frame and by sliding mesh method, but in my case i have to rotate the inner side of the cylinder by 7 degree only.
In case of both MRF and sliding mesh method we can't maintain the rotation upto 7 DEGREE. I have studied the 9 TH chapter- It say we can do this option by using Dynamic mesh method. It say's we have to develop a program using UDF.
My probem is to rotate the inner cylinder grid by 7 Degrees only. I am not very clear with the UDF's. If you could help me that will be a great information for me to solve my problem.
Thanks and regards,
Karthik Krishna
Old   February 23, 2005, 07:13
HVN
So now I understand what you try to simulate. Normally you could use for that the 2 udf that you speak about in your first message.
HV
Old   February 23, 2005, 07:57
Karthik Krishna
Dear Sir,
Yes, I am trying to simulate the inner cylinder grids using the 2 udf. But I am not very clear which to use for my Problem.
If there is any sample problem, similar like my problem it will be very much useful.
Thanks and regards,
Karthik Krishna
modification of fractional step for moving grid Wei Main CFD Forum 3 May 13, 2006 21:30
moving mesh grid interface Dieter FLUENT 6 March 23, 2006 06:54
how use moving grid in fluent hamed FLUENT 3 October 26, 2005 03:09
Moving Body Grid Question Matt Main CFD Forum 5 September 13, 2004 00:45
Unstructured moving grid M.A.Leschziner Main CFD Forum 0 July 15, 1999 07:25
