B.C Edges
Old   February 15, 2005, 20:26
Default B.C Edges
Ard
How can I define for example edge 1 and edge 2 as just one edge. These edges share the same vertex.
I need to do this as egde 1 and edge 2 have the same B.C or does it matter if I just define them with the same B.C whereby two edges with the same vertex has the same B.C. Will Fluent have problem with this.
These edges form one straight vertical line.
THX.
Old   February 17, 2005, 05:47
Default Re: B.C Edges
JB
I think it's ok if you assign the same BC to both of your edges.
cheers, jb
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Gambit-how to create a wireframe face from so many edges? gholamghar ANSYS 0 February 18, 2011 07:22
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
