Particle Injections
Old   February 21, 2005, 09:49
Default Particle Injections
Colm2k
I am currently investigating particle transport in microfluidic channels. The particles I am interested in are solid particles with the same density as silicon. I have created such a solid material in the materials database. However when I then go to injections and search for the new silicon material as the injection type it is not there available for selection. The range of solid materials there is actually quite limited. Any help would be much appreciated as this is proving a major stumbling block in my research.
Thanks in advance,
Colm
Defining DPM Particle Injections with a UDF TedBrogan FLUENT 0 April 18, 2011 16:45
Time delay particle injections denyfrank FLUENT 0 February 3, 2011 14:04
Multiple surface particle injections from the command line mbeals FLUENT 0 June 3, 2009 14:11
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
Particle injections Virag Mishra FLUENT 0 August 22, 2007 05:11
