solid heat source
Old   February 18, 2005, 01:37
Default solid heat source
ocy
Hi all,
I am doing heat transfer through a channel. The channel is a 2D rectangle. The air flows in from the bottom, and flow out at the top.
As the air flows in, it is being heated by a solid heat source.
In my modeling, i marked out a small square (which has the same width as the rectangle) at the bottom to simulate as heat source.
However, ONLY my solid face zone shows temp variation, the remaining fluid face zone shows a constant ambient temperature.
Does anyone know why isn't my fluid being heated? Is there anything that i did wrong?
Thanks in advance to anyone who reply.
Old   February 18, 2005, 12:11
Default Re: solid heat source
Evan Rosenbaum
The heated zone and the unheated zones must share common faces where they meet. Make sure you merge coincident edges before exporting your mesh. This can cause the effect you describe.
Old   February 21, 2005, 05:16
ocy
Hi Evan,
My heat source is a small square measuring 0.4m x 1m at the base of my chimney which is 1m x 50m.
How can I let them share a common face? I tried to merge faces, but error message suggested that the two faces are not connected.
Pls help. Thanks.
Old   February 22, 2005, 22:58
Bikash
i guess u got to merge the edge not the face cause its 2D.
if your heat source, the small square is within the chimney then u got to merge the edge.i guess they are sharing the common edge right?
if u still have problems then first draw lines in gambit, then create face using wireframe model.
hope i understood your problem right.
take care.
how to load the heat source to wall david yang Main CFD Forum 1 October 12, 2009 13:34
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
heat conducting in a solid domain Rogerio Fernandes Brito CFX 0 March 18, 2008 17:20
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
