March 1, 2005, 01:22 |
heat transfer not working well
Hi all,
I have a vertical duct where there is air inside. The bottom walls of the duct heat up the air as it flows in through the inlet. When i remove the insulation of the wall, only a small region near the wall shows temp decrease. The main bulk of the air still maintains a high temp. Is this normal? or have i done something wrong? Pls help. Thanks in advance |
March 2, 2005, 11:42 |
Re: heat transfer not working well
Check your flow regime. If you have laminar flow, you would expect a near-wall effect only.
Heat transfer (conduction) between two pipes | shields | FLUENT | 14 | February 3, 2016 07:45 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 22:22 |
MRF and Heat transfer calculation | Susan YU | FLUENT | 0 | June 2, 2010 08:46 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
