Create a time related function
Old   February 28, 2005, 08:51
Default Create a time related function
Eric
As we knew fluent using steady flow for all the cases. but in some cases, if we wanted to create a unsteady mass flow for the stimulation. what can we do? simply to say, let me simply the problem of inlet mass flow rate be 30sin(pi * t)+ 90. then how can we change the way of steady flow to such unsteady flow.
was it done by creating a user defined function? or something else? please help me
Old   March 2, 2005, 05:06
Default Re: Create a time related function
Melaku H.
I don't know your particular problem but in general it is possible to write a simple UDF code to do just that!
Melaku H.
Old   March 3, 2005, 08:03
peter
A very closely related example (transient velocity profile) is given in section 11.1 of the FLuent 6.1 UDF manual)
Old   March 3, 2005, 12:30
Eric
OK, i try to use this . Besides, how can i change it similarly so that a UDF of preesure can be constructed?
thanks For peter
Old   March 4, 2005, 10:58
Eric
but as i think more carefully, the UDF in the section 11.1 only give a varying flow pattern along different distance. this is not the problem i wanted to solve. what i need is the way which the flow of the whole region with a mass flow rate vary with respect of time. As the way of 11.1 only provided the minimum velocity in the middle of region.
so i think this is not the same case. what can i do ???
thanks in advance
Old   March 14, 2005, 14:53
matt
Hi Eric,
If you want to vary the inlet boundary condition with respect to time how about trying the DEFINE_PROFILE macro - something like of Example 1 in Section 4.3.13, UDF Manual with time being the variable in the function.
Declare time as a variable and then as equal to the value of a time dependent macro as in Section 6.7
good luck,
matt.
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
