March 14, 2005, 12:36 |
3D Flow over a circular cylinder
hi, i am using FLUENT 6.1 to solve 3D flow over a circular cylinder in unbounded domain.i could validate drag(CD) and St for unsteady flow past a circular cylinder in 2D. But in my 3D calculations, the drag values for Re =100,200,300 are coming to be higher if i use a boundary layer on cylinder and lower if i dont use a Blayer. What could be the fault in my computations using FLUENT ??? please suggest me the efficient way to use FLUENT for 3D computations.
March 15, 2005, 03:15 |
Re: 3D Flow over a circular cylinder
What do you mean boundary layer on cylinder?
March 15, 2005, 13:04 |
i attached boundary layer on the cylinder surface using the option available in Gambit
March 15, 2005, 20:57 |
well i have also observed such behaviour that if i use prism meshes near the walls of cylinder i get higher CD and if i am using tet meshes (i am using LES as model) i get better CD values (by better i mean close to experimental values). i am not able to figure out why. but i have observed that if i use ke-realisable with prism meshes near walls the results are close to experiments but then with k-e-realisable and tet meshes near wall the CD values are low.
Display Modes | |
Particle deposition on circular cylinder in turbulent flow | Julian K. | CFX | 1 | October 3, 2011 18:51 |
Which Solver/Model to use for flow over Circular Cylinder ? Re [1 , 10^6] | WolfgangS. | OpenFOAM Running, Solving & CFD | 1 | December 6, 2010 03:48 |
3D FLOW OVER A CIRCULAR CYLINDER | Srinivas Mettu | FLUENT | 2 | April 4, 2010 23:11 |
flow past a circular cylinder | Senthilkumar | Main CFD Forum | 2 | April 20, 2009 00:18 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
