February 28, 2005, 09:51 |
Create a time related function
As we knew fluent using steady flow for all the cases. but in some cases, if we wanted to create a unsteady mass flow for the stimulation. what can we do? simply to say, let me simply the problem of inlet mass flow rate be 30sin(pi * t)+ 90. then how can we change the way of steady flow to such unsteady flow.
was it done by creating a user defined function? or something else? please help me |
March 2, 2005, 06:06 |
Re: Create a time related function
I don't know your particular problem but in general it is possible to write a simple UDF code to do just that! Melaku H. |
March 3, 2005, 09:03 |
A very closely related example (transient velocity profile) is given in section 11.1 of the FLuent 6.1 UDF manual)
March 3, 2005, 13:30 |
OK, i try to use this . Besides, how can i change it similarly so that a UDF of preesure can be constructed?
thanks For peter |
March 4, 2005, 11:58 |
but as i think more carefully, the UDF in the section 11.1 only give a varying flow pattern along different distance. this is not the problem i wanted to solve. what i need is the way which the flow of the whole region with a mass flow rate vary with respect of time. As the way of 11.1 only provided the minimum velocity in the middle of region.
so i think this is not the same case. what can i do ??? thanks in advance |
March 14, 2005, 15:53 |
Hi Eric,
If you want to vary the inlet boundary condition with respect to time how about trying the DEFINE_PROFILE macro - something like of Example 1 in Section 4.3.13, UDF Manual with time being the variable in the function. Declare time as a variable and then as equal to the value of a time dependent macro as in Section 6.7 good luck, matt. |
Display Modes | |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 02:07 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
