Velocity Inlet
Old   March 17, 2005, 15:54
Default Velocity Inlet
David
Hi everybody,
I have read somewhere that when entering text commands UDF cannot be used to define boundary conditions such as an velocity inlet although the UDF are used to define such conditions when using the GUI. Can someone confirm?
Secondly, if this is true what is the alternative mean to define a time-dependent parabolic profile at the inlet of a pipe.
Many Thanks David
Old   March 18, 2005, 02:23
Default Re: Velocity Inlet
Y
Can it make it clear Y
Velocity Inlet BC -- Flow Reversal salihovic FLUENT 0 May 8, 2011 05:45
Changing Boundary: Decreasing Inlet Velocity - Convergence Issues VT_Bromley FLUENT 3 February 12, 2011 09:02
User Defined Profiles, Swirl, Velocity Inlet saurus FLUENT 0 January 26, 2011 15:35
Unexpected difference between velocity / mass-flow inlet jpo FLUENT 8 December 10, 2010 07:20
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
