missing mass from dpm model
Old   March 23, 2005, 18:05
Default missing mass from dpm model
Jan Rusås
Dear Fluent user I am calculating a 3d problem with oil combustion. I have very big problems with obtaining the specififed mass flow. I use a pressure swirl injector but I do only get at maximum 10% of the mass specified, when I calculate the sum of the volume mass source from the DPM. If I do not included droplet collision and breakup I do not have any problems, but when I initiate coll. and breakup then does the mass vanish. I have tried to do the calculation on a simplified 2d model of my problem and I could get an solution in this case.
I have tried several things, number of particles per cell, injected number of particles, increasing the temperature, adjusting number of flow iterations, under relaxation etc.
Please share how you have solved this problem Thanks in advance Jan
How to put melting point data of inert particle in DPM model of Fluent subhankar_bhandari Fluent UDF and Scheme Programming 1 February 5, 2018 07:08
DPM mass balance help jpinho FLUENT 1 April 25, 2014 06:48
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Questions on DPM model..please panos_metal FLUENT 3 October 7, 2010 06:26
Missing Information in SST Transition Model Formulation Josh CFX 2 September 14, 2010 11:49
