NACA 0018 Airfoild in high speed flow
I'm looking for information on a NACA 0018 airfoil. I have results (Pressure coefficient distribution is what I'm concerned with) for the airfoil in the incompressible flow regime which match well with my model, but when I run the model at Mach 0.6, I'm getting a slightly different profile of the Pcoef along the airfoil which seems to be a compressibility effect. I was wondering if anyone has any references with Pressure distributions for a NACA 0018 above Mach 0.3 (or any other NACA symmetric airfoil would be helpful to look at trends).
Thank you in advance! Jason |
Re: NACA 0018 Airfoild in high speed flow
you might want to try NASA archives or lanl gov archives. They might have the data for NACA airfoils archived
although it is a bit dated. Theory of Wing Sections by Abbott is a good reference. Some of the Nasa and Naca reports may be available online as well. Best Luck, Bak_Flow |
