April 13, 2005, 11:48 |
viscosity setting in compressible case
Guys,
I got a question regarding viscosity setting in Fluent. I am modeling a subsonic/supersonic case (turbomachinery). My question is that should I set the viscosity to be constant (density is set to ideal-gas) or should it be a function of temperature (linear, power law, etc)? The reason I am asking is that viscosity is temperature dependent in compressible case theoretically, but in the nozzle tutorial of Fluent 6 (supersonic case) they leave viscosity as constant. Your help would be greatly appreciated. Thanks a lot! |
April 13, 2005, 13:20 |
Re: viscosity setting in compressible case
I'd recommend using the three-coefficient Sutherland law.
April 13, 2005, 13:44 |
Thanks a lot!!!!! I will do that.
How to export the specific heat and viscosity for postprocessing (compressible) ? | david39 | OpenFOAM Post-Processing | 2 | January 4, 2019 07:04 |
Changing the grid on the same set-up | Katya | FLUENT | 7 | October 8, 2009 16:31 |
Ultra high temperature? | bk | Siemens | 2 | July 19, 2005 00:01 |
Body force - Does it work? | Jan Rusås | CFX | 5 | August 27, 2002 09:50 |
Viscosity Variation for Compressible Flow | NIK Durrani | Main CFD Forum | 1 | July 22, 2002 08:48 |
