Fluent - Iterate Command
Old   April 8, 2005, 15:13
Default Fluent - Iterate Command
Harish
The geometry was created in gambit and I saved the mesh and imported it into fluent and set the flow conditions and properties and also the necessary information for the solver. But I run into a weird problem , I cannot click the iterate button to run the solver. I'm not sure if I need to have my administrator have a look at it or is it some setting which i need to modify .
Harish
Old   April 8, 2005, 15:17
Default Re: Fluent - Iterate Command
pUl|
Did you initialize first? Solve -> Initialize -> Initialize.
Old   April 8, 2005, 21:53
Harish
I initialised the solution and also set other solver controls. There seems to be some buttons in the menu which are dimmed and i cannot use them and iterate is one of them .
Old   April 8, 2005, 21:55
pUl|
No idea, which version of fluent are you using by the way?
Old   April 11, 2005, 22:18
zxaar
yaar, this would be easy hack, first set up simple laminar case, initialise the case, if u see the iterate button and can iterate few times, set up ur model and directly go to iterate without initialisign again. i used to do this, when on combustion cases ..on initialization fluent gives segementation violation error, and it used to work fine.
Old   April 12, 2005, 03:30
Luca
If you write from the TUI: it 1 does Fluent start iterating? Luca
fluent text command doesnt show all options! m2montazari FLUENT 3 March 12, 2017 23:56
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 13:43
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
Fluent Export Command Issue .... Leo Hindarto FLUENT 0 January 3, 2009 23:20
How do you kill Fluent from the command line? Hugo FLUENT 3 May 25, 2007 09:52
