MSH to DBS File
Old   April 13, 2005, 03:12
Default MSH to DBS File
Sham
I want to convert MSH file to DBS file. I went to Import Mesh in gambit but somehow it does not work. Can some one pls tell me the right way to do it. Thanks.
Sham.
Old   April 13, 2005, 06:01
Default Re: MSH to DBS File
zxaar
it should work, selet the 3d option if u r importing it (3d file,), and make sure u have select fluent mesh in import
Old   April 14, 2005, 01:17
Sham
I have tried so many time and it just does not work. what do you specify for the featured angle?
Sham.
Old   April 14, 2005, 18:20
zxaar
this sounds starnge, because reading .msh in gambit is one thing without which i could not survive, this is the answer to all my complicated cases, and i use this daily,
anyway, see if u can read the mesh in fluent, if u can read the mesh in fluent, u shall be able to read it in gambit,
so if u can read it in fluent, save the cas file, and instead of .msh import the mesh by .cas file in gambit it shall work
Old   April 14, 2005, 21:23
Sham
Thanks zxaar,
I have tried that and it gives the same error. It says.;
Error encountered while reading the header information.
Error: The FIdap neutral file header is non standard.
Sham.
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 17:33
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
