May 11, 2005, 03:28 |
Modeling Adsorption/Packed Beds
Hi all, My system is that there is a liquid (containing some solutes) that flows through a porous medium. I need to model the adsorption of the solutes to the porous media.My aim is to determine the concentration of the solute in the porous media after adsorption takes place. I dont find any of the multiphase models in Fluent helpful in my case. Can anyone suggest what is to be done?
May 12, 2005, 15:32 |
Re: Modeling Adsorption/Packed Beds
I think you are a little bit beyond the CFD capacity of the moment ... However depending on what you are really looking for i guess a simulation can give you some indication ... Your problem is not multiphase but multi-species [water + solutes]. What i would do in your case is to try to find a kinetic of adsorption in your system, basically the kinect of conssuption of your solutes. Assuming an isotropic media you may be able to obtain some useful results !
May 13, 2005, 02:05 |
Thank you Thomas I do have the kinetics of adsorption, i.e. the rate of adsorption, the adsorption coefficient etc., and I write a UDF (based on simple mass transfer) for it. The real problem is that there is an oxidation reaction (between oxygen and the solute) on the porous media after the adsorption of the solute takes place. I need to know how much of the solute is adsorbed. The Langmuir model gives a relation between equilibrium concentration of the solute in the liquid and the adsorbed solute on the solid. Generally the values of equilibrium concentration are not available. I want a relation between the concentration of the solute in water (at any time,space) and the amount of it that is adsorbed...
Please Help. |
September 25, 2010, 14:19 |
Adsorption
masters
hi sudheendra, My problem is also related to adsorption.can u please tell me how to proceed or can u give me any info about that one??
April 21, 2013, 04:09 |
adsorption of bezene on activated carbon
soodabe
Hi all,My system is a mask made of activated carbon for adsorption of air pollutants(for example benzene),and any real chemical reaction doesnt take place in my system,but I know that in fluent I should define an elimination reaction instead of adsorption for solving the problem.
I have 2 problem: 1-how many UDF in fluent are needed? 2-What functions should I define in UDF? please help me. |
Modeling adsorption in packed beds | Julia | FLUENT | 3 | May 13, 2013 03:39 |
May Focus Area: Turbulence Modeling | Jonas Larsson | CFD-Wiki | 0 | May 2, 2006 11:48 |
Modeling Flow/Saturation/Absorption in Fibers | Gene Dougherty | Main CFD Forum | 0 | June 6, 2003 14:49 |
Solid Modeling | Chris | Main CFD Forum | 10 | July 2, 2002 07:12 |
CFD Modeling of Two-phase Flow in Small Dia.Tubes | Eric Poindexter | Main CFD Forum | 2 | September 22, 2000 09:21 |
