LES fully developed channel flow
Old   May 9, 2005, 11:16
Default LES fully developed channel flow
Gem
I am testing Fluents 6.1 Large Eddy Simulation capability using fully developed channel flow as the test case. I have carried out the simulation, however i am having difficulties with the post-processing stage. I have enabled the data sampling for data statistics option in the iterate panel and ran the simulation for 8 flow through times. However when I display the velocity contours for the instanteous and mean x, y and z velocities they are exactly the same, the RMS values are very small. How do I enable Fluent to correctly output the instanteous, mean and RMS x, y and z velocities to display the velocity contours/data? does anyone know if there is a bug in fluent when using the data sampling option, I think it might be collecting data over one time step only and not over the 8 flow through times.
Old   May 10, 2005, 03:23
Default Re: LES fully developed channel flow
anindya
I faced the same problem as yours but could not find any solution even after posting it here several times.
I have ran different cases with different settings, but everytime I saw that the mean and the instantaneous results were the same even after running them for several thousand time steps (hundred thousand or more iterations).
I strongly feel that there is a problem with LES model in Fluent 6.1.
Anindya
Old   May 10, 2005, 05:32
Gem
Anindya,
Thanks for your post. Did you manage to solve the problem by using a different version of Fluent?, if so what version did you use? Did you find any alternative way of outputting the mean and instanteous velocities?
Thanks
Gem
Old   May 10, 2005, 18:26
Anindya
I just had fluent 6.2 installed. I am going to run it and see if the new les models/settings helps me to get better results.
I will let you know if I manage to get better results. Btw what was your problem size (# 0f cells)and time step size and no of time steps?
Old   May 12, 2005, 05:30
Gem
the size of the computational box is 7.85 (x), 2(y), 4.71 (z). the grid size is 64x82x82. no of time steps = 3,500 timesteps (3 flow through times) prior to setting up the data sampling for data statistics.
LES channel flow ilia OpenFOAM Running, Solving & CFD 7 April 18, 2011 16:58
LES turbulence decaying in channel flow cfdIsMad Main CFD Forum 6 August 21, 2009 12:17
BC for fully developed turbulent flow in a pipe mmd014 FLUENT 2 May 22, 2009 06:50
LES In Turbulent in channel flow pankaj saha Main CFD Forum 8 April 15, 2009 11:34
Outlet Boudary Condition for Fully Developed Flow Saad Main CFD Forum 5 November 19, 2004 13:22
