May 15, 2005, 04:15 |
Pretty Pictures
I'm trying to post-process (visually) an unsteady simulation.
I would like to look at cross sections of my 3D domain. Is this easy? Docker |
May 15, 2005, 23:37 |
Re: Pretty Pictures
I saw my classmate use tecplot to do this once, but I don't know how to do it exactly.Try tecplot, it may help you.
May 16, 2005, 03:11 |
Re: Pretty Pictures
Yes You can do that in FLuent. You have to create a plane. Go under the menu surface. When created you will see in the post-processing panel the name of the plane you created. then you can work as usual. Luca
May 16, 2005, 11:01 |
Re: Pretty Pictures
You can also try the Display>Sweep Surface panel. From there you can also create animations.
Edi. |
May 17, 2005, 07:56 |
Re: Pretty Pictures
THANKS all of you for responding.
Much appreciated. Docker |
May 18, 2005, 00:43 |
Re: Pretty Pictures
Read this link for making animation in better way.
http://www.fluent.com/about/news/new...00v9i2/a23.htm VenuGopal. s |
Setting Boundary Conditions (pretty pictures!) | Riaan | FLUENT | 0 | October 6, 2005 16:23 |
Convert color-scale pictures to gray-scale ones | XC | FLUENT | 4 | March 29, 2005 18:55 |
Can I put pictures in my post? | darcy | Main CFD Forum | 5 | March 20, 2001 23:59 |
Postprocessing and pretty pictures | tom | Main CFD Forum | 1 | September 29, 1999 15:36 |
Pictures and Equations? | andy | Main CFD Forum | 3 | December 11, 1998 09:51 |
