Pretty Pictures
I'm trying to post-process (visually) an unsteady simulation.
I would like to look at cross sections of my 3D domain. Is this easy? Docker |
Re: Pretty Pictures
I saw my classmate use tecplot to do this once, but I don't know how to do it exactly.Try tecplot, it may help you.
Re: Pretty Pictures
Yes You can do that in FLuent. You have to create a plane. Go under the menu surface. When created you will see in the post-processing panel the name of the plane you created. then you can work as usual. Luca
Re: Pretty Pictures
You can also try the Display>Sweep Surface panel. From there you can also create animations.
Edi. |
Re: Pretty Pictures
THANKS all of you for responding.
Much appreciated. Docker |
Re: Pretty Pictures
Read this link for making animation in better way.
http://www.fluent.com/about/news/new...00v9i2/a23.htm VenuGopal. s |
